Thread started 07 Feb 2011 (Monday) 16:52
How would I correct the pink tinge on skin?
Rachel ­ B
I normally pay attention
Feb 07, 2011 16:52 |  #1
I just got this cool pink paper, but I am having a problem with it reflecting on the subject.
This pic is under exposed, and because of that it should be a reject, how ever I think its cute and really would like to attempt fixing it.
Her head is picking up so much pink from the paper I am not sure how to go about correcting this shot. I use LR and Photoshop Elements.
IMAGE: http://farm6.static.flickr.com/5136/5425917613_90c77c9145_b.jpg
IMAGE LINK: http://farm6.static.fl​ickr.com …25917613_52147b​17e4_o.jpg  (external link)
I would assume if shooting a baby crawling on Pink I should get a low white reflector to shine white on her face if I was to re shoot this? but for now I am interested in correcting the image.
40d, 30d, Canon 17-40L, 70-200 2.8 ISL, 60mm 2.8, Sigma 30mm 1.4, 18-55 Kit, 430exII 2xYN-460 II Flashes
Rimmer
Joined Nov 2010
Feb 07, 2011 17:56 |  #2
Just real quick -- gotta run to supper, more later, I hope --
In Elements, use the Magic Selection Brush to select all of the pink area. Invert the selection. Use Select > Refine Edge to expand/contract as needed and to feather the edge a bit. Add a Hue/Saturation layer, which will be masked by the (inverted) selection. In the HSL panel, select Reds from the drop-down (says Master by default) then click on the first eyedropper tool and click that on the pink under the baby. Run the Saturation slider back to -70 or so.
See if that doesn't look better to you -- that should at least get you started in the right direction.
Ace Rimmer -- "What a guy!"
"Smoke me a kipper, I'll be back for breakfast." ;)
MrAl
Joined Nov 2010
Feb 07, 2011 18:44 as a reply to  @ Rimmer's post |  #3
If that didn't work start fresh and open a curves adjustment layer and use the grey eye dropper on the white of the left eye as you look at the image. then select the background layer again and open a new layer above that now with the eye dropper tool select a tone on the child's face that is neither in the shadow or highlight and not pink. Now grab a paint soft brush of a medium size and paint over the pink. Set that layer to color and back the opacity back to ~28% or to your liking.
Rimmer
Joined Nov 2010
Feb 07, 2011 18:50 as a reply to  @ Rimmer's post |  #4
OK, I'm back. -70 on the Saturation is a bit much, maybe more like -50. Also, after you get the selection inverted you will need to paint some black on the mask to protect the brown rug and logo from the Saturation adjustment. Finally, I added a Levels layer and moved the right slider back to 233 to brighten, and then used the Shadows/Highlights control to bring the shadows up a bit and the highlights down a bit. I know next to nothing about photographing people so I'm just tinkering at this point. Well, maybe anyway this gives you one thing to try until someone more experienced jumps in. :cool:
Peano
Feb 07, 2011 18:52 as a reply to  @ Rimmer's post |  #5
Select the skin (by whatever means you have in Elements). Open a curves adjustment layer. The selection will create the mask. In curves:
- increase red,
- increase green to the point where skin tones begin to look slightly yellow, then
- increase blue to compensate for that.
Set the control points for these changes on the skin tones. If you're not comfortable with curves, color balance will do it. Work mostly in the highlights.
IMAGE: http://img8.imageshack.us/img8/2840/pinkbaby2.jpg
Peano
RadiantPics.com (external link)
ChasP505
"brain damaged old guy"
Feb 07, 2011 19:23 as a reply to  @ Peano's post |  #6
I cheated and used 2 NIK apps-- ColorEfex Pro and Viveza. I used ColorEfex Pro to remove the color cast from skin and reflective parts of her dress. Used Viveza to lighten shadows somewhat.
Chas P
Peano
Feb 07, 2011 19:40 as a reply to  @ ChasP505's post |  #7
This is purely a matter of personal preference, but I think a muted, complementary background would do this little cutie
more justice. (I haven't wiped out all the pink. Just a quick illustration here.)
IMAGE: http://img222.imageshack.us/img222/1299/pinkbaby2a.jpg
Peano
ChasP505
Feb 07, 2011 20:09 as a reply to  @ Peano's post |  #8
Wow... With a different color background, you can really see how much pink is reflected in the ribbon on the dress.
Chas P
Peano
Feb 07, 2011 20:44 |  #9
ChasP505 wrote in post #11798154 (external link)
Really! It spilled all over everything. I'm just guessing that this is closer to reality.
Still pink reflected off the sequins and in the shadow under her arm on the right.
IMAGE: http://img143.imageshack.us/img143/3869/pinkbaby.jpg
Peano
ChasP505
Feb 07, 2011 20:59 |  #10
Peano wrote in post #11798381 (external link)
Damn fine job, David!
Chas P
D ­ Thompson
Feb 07, 2011 21:22 |  #11
Very nice job.
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
Peano
Feb 08, 2011 07:40 |  #12
Thank you Chas & DT
Peano
sssc
Gallery: 32 photos
Feb 08, 2011 08:58 |  #13
That is great work all of you. My Inspiration for the day!!
Keith-EOS R 7D MarkII EOS REBEL T2i 18-55,55-250.85 1/8. 100-400L. 10-22 f/3.5-4.5. 24-105mm f/4L IS,70-200 II,RF 24-105
lecherro
Feb 08, 2011 15:44 |  #14
I followed Rimmers advice and this is the result. It took about 15 minutes I also cropped out the bottom and fixed some spots in the pink.
First step........ Take the lens cap off.
Rachel ­ B
Feb 08, 2011 17:48 |  #15
Thank you very much for the help everyone....and seeing the fixes, gives me something to work towards!
2,890 views & 0 likes for this thread, 11 members have posted to it.
2734 guests, 140 members online
