what program are you using to rename multiple pictures at one time instead of having to edit them one at a time?
G-1000 Member 98 posts Joined Jul 2010 Location: North Cali More info | Feb 08, 2011 00:03 | #1 what program are you using to rename multiple pictures at one time instead of having to edit them one at a time? T3i | 24-70L I | 50mm 1.8 I | 40mm | 28mm 1.8 | 550EX | | Aperture 8 | Lightroom 5
Staszek Goldmember 3,606 posts Likes: 4 Joined Mar 2010 Location: San Jose, CA More info | Feb 08, 2011 00:10 | #2 Lightroom SOSKIphoto
professoryeti Senior Member 573 posts Likes: 1 Joined Oct 2009 Location: Charleston, WV More info | Feb 08, 2011 00:15 | #3 If you just want to batch rename inside the finder use the Automator. Google it if you need help but basically you tell it to perform tasks in a certain order I.e. 1. Gather selected files. 2. Sort by creation date. 3. Rename to -------- Saturnalia for all you have.
jnaks Senior Member 474 posts Joined Mar 2010 Location: Oahu, Hawaii More info | Feb 08, 2011 01:18 | #4 Adobe Bridge will also let you rename the images. If you can read this, you don't need a macro | 7D + 5DIII + Waaaay too much spent....
Damian75 Goldmember 1,623 posts Likes: 6 Joined Dec 2006 Location: PA More info | Feb 08, 2011 03:59 | #5 professoryeti wrote in post #11799444 If you just want to batch rename inside the finder use the Automator. Google it if you need help but basically you tell it to perform tasks in a certain order I.e. 1. Gather selected files. 2. Sort by creation date. 3. Rename to -------- ^^^ This is what I do if I am renaming files in the finder. Most of the time with images I set the naming scheme at import and let Aperture do it for me. Canon EOS 40D,30D, Canon 70-200 2.8L, 24-70 2.8L, 85 1.8, Canon extension tube, Elinchrom Lighting gear,
othomas Senior Member 531 posts Joined Oct 2005 Location: Midlothian, Scotland More info | Feb 08, 2011 14:23 | #6 I use Lightroom, but if you don't have it then use an Automator script.
Feb 08, 2011 17:45 | #7 thanks for your inputs...right now automator does the job...once I save up on some money im gonna be looking into some of those adobe programs mentioned T3i | 24-70L I | 50mm 1.8 I | 40mm | 28mm 1.8 | 550EX | | Aperture 8 | Lightroom 5
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Feb 08, 2011 20:33 | #8 Again... Lightroom. [Gear List | Flickr
| Latest registered member is MWCarlsson 928 guests, 181 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
