kuraz wrote in post #11801825
Soft focus (which you mentioned). Try placing something there in your place, focus on it, use a greater f/stop since your are doing a self portrait, run in that exact spot making sure you are in the same focal plane as the item was and let the photo snap. Try using something with words on it to stand in your place and take a picture of that before you take a picture of yourself. That way you can see if you were too far back or too close. Takes time to do this and I haven't had to the time to play with self portraits too much but it worked out when i tried it.
Other than that, don't cut your elbow off. If you would have gotten the elbow and the complete forehead in the frame I think it would be a little better.
Hope that helps. Good luck with the new setup
Thanks, Was actually shooting at f11, hoping that would work. ON back of camera it looked good. Of course after 20 or so pics screwing aroudn, then throwing them up on a 27" imac. BIG DIFFERENCE! The way i was trying to crop on lightroom, turning the pic, it had to cut elbow off. I guess i could use photoshop and clone backround to make it square again. No biggie, just learning right now. It was 5am when i took those. haha
