I noticed that this has been done plenty of times before. I just wanted to give everyone the version that I made after thinking about it one day while I was at Lowe’s. I have done may write ups before on other forums, mostly for my Honda S2000, but this is going to be my first on a photography forum so be easy on me! Now this only cost me $15.37 to make and is heavy duty. I thought about making one out of PVC, but realized it wouldn’t last as long and wouldn’t be as structurally sound. Any feedback is welcomed. I also made this DIY in about 30 min with taking pictures (and the pictures are horrible!) so it doesn't take much time at all. Here we go.
Here is a list of the materials needed:
(1) 1/2” x 12” Galvanized Steel Pipe
(1) 1/2” x 8” Galvanized Steel Pipe
(1) 1/2” x 6” Galvanized Steel Pipe
(1) 1/2” Galvanized Tee
(1) 1/4-20x1 Stainless Steel Locking Nut
(1) 1/4-20 x 1-1/2 Stainless Steel Hex Cap Screw
(1) 1/4 -20 Stainless Steel Wing Nut
(1) 1/2” x 1/2" FPT Barb Brass Female Adapter
(2) 1/2" Galvanized Caps
![]() | HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FLICKR |
Materials Needed
First, we are going to put together the base. You will need the pictured items:
Base Materials
Here is how they will be laid out. You will take the 1/2” x 1/2" FPT barb brass female adapter and insert the 1/4-20 x 1-1/2 stainless steel hex cap screw into it. The 1/4-20x1 stainless steel locking nut will then secure the hex screw to the brass fitting. The wing nut will then go wings down onto the screw to secure the camera.
Layer of Base
Here is how I secured the nut to the screw.
Putting the Base Together
Here is how it looks inside. You will not see this part once it is installed.
Inside of Base
And, here are side views without the wing nut and with the wing nut.
Side View of Base
Base with Wing Nut
