I am looking at a Mettle Studio Strobe which is a Bowens S Mount and would like to know if its possible to buy an adapter to use light modifiers made for the Elinchrom or AlienBee's strobes.
I have looked but must be missing what I'm looking for.
Thorrulz Goldmember More info | Feb 08, 2011 19:25 | #1 I am looking at a Mettle Studio Strobe which is a Bowens S Mount and would like to know if its possible to buy an adapter to use light modifiers made for the Elinchrom or AlienBee's strobes. Flickr
dmward Cream of the Crop More info | Feb 08, 2011 21:34 | #2 Its possible to buy adapter rings that fit most speedrings to change from S mount to Elinchrom to AB. David | Sharing my Insights, Knowledge & Experience
tetrode I am a walking repository of thoroughly useless information 3,777 posts Likes: 6 Joined Jan 2006 Location: New York More info | The mount on the Mettle lights cannot be changed nor is there an adapter to convert the Mettle's Bowens mount to Elinchrom or anything else. If you were hoping to use Elinchrom Rotalux softboxes/octaboxes on the Mettle, that (for all practical purposes) is not possible either as the Rotalux modifiers have an integral speed ring insert that cannot be changed.
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Feb 08, 2011 22:12 | #4 tetrode wrote in post #11805739 The mount on the Mettle lights cannot be changed nor is there an adapter to convert the Mettle's Bowens mount to Elinchrom or anything else. If you were hoping to use Elinchrom Rotalux softboxes/octaboxes on the Mettle, that (for all practical purposes) is not possible either as the Rotalux modifiers have an integral speed ring insert that cannot be changed. On the up side, the Bowens mount is undoubtedly the most widely used mount of them all. Any modifier that takes a standard speed ring with interchangeable inserts can be adapted for use on the Mettle. All you'd be losing is access to brand-specific modifiers like the Elinchrom deep octa, for example. Dave F. Are you saying you can't adapt a Bowens speed ring to an Elinchrom modifier mount even by using a go-between adapter like the Kacey Eli adapter? I would think that should work, no, just like you can adapt an AB/Balcar speed ring to an Eli modifier? ...Leo
tetrode I am a walking repository of thoroughly useless information 3,777 posts Likes: 6 Joined Jan 2006 Location: New York More info | Feb 08, 2011 22:30 | #5 PacAce wrote in post #11805890 Are you saying you can't adapt a Bowens speed ring to an Elinchrom modifier mount even by using a go-between adapter like the Kacey Eli adapter? I would think that should work, no, just like you can adapt an AB/Belcar speed ring to an Eli modifier? Leo, Leo, Leo, you're overlooking my carefully chosen weasel words: "for all practical purposes". Sure, you could bolt a Kacey Elinchrom adapter to a 152mm diameter FLAT Bowens speed ring insert (very rare) and, in so doing, allow a Rotalux modifier to be physically attached to a Bowens mount light (such as the Mettle). Would you want to? Not likely. The thickness of the adapter sandwich is going to place the Mettle's flash tube at the back end of a short tunnel. That, of course, is going to take a toll on light dispersion within the modifier.
Feb 09, 2011 06:59 | #6 I was looking at the 300W or 600W Mettle AC/DC Strobe HERE Flickr
FJLOVE Cream of the Crop 20,883 posts Likes: 82 Joined Nov 2006 Location: barrie ont. ca More info | Feb 09, 2011 07:09 | #7 elinchrom D lite 4 here http://www.bhphotovideo.com …G/Elinchrom_EL_20484.html DILLIGAF about your bicycle or your gear
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Feb 09, 2011 08:00 | #8 tetrode wrote in post #11805974 Leo, Leo, Leo, you're overlooking my carefully chosen weasel words: "for all practical purposes". Sure, you could bolt a Kacey Elinchrom adapter to a 152mm diameter FLAT Bowens speed ring insert (very rare) and, in so doing, allow a Rotalux modifier to be physically attached to a Bowens mount light (such as the Mettle). Would you want to? Not likely. The thickness of the adapter sandwich is going to place the Mettle's flash tube at the back end of a short tunnel. That, of course, is going to take a toll on light dispersion within the modifier. If the goal is to use Elinchrom modifiers as they were designed to be used, I would think the best solution is to buy a light that has an Elinchrom compatible accessory mount. If even D-Lites don't fit the budget, there's nothing wrong with the Calumet Genesis lights or Interfit EXD series. Dave F. Thanks for the clarification, Dave. So, the Eli adapter is really only useful for adapting PCB stobes and others that use the Balcar mount due to the thickness of the Eli adapter? Never thought of it that way but it does make sense since the Balcar mount is the only one I can think of that can be "flattened" to compensate for the thickness of the Kacey Eli adapter. ...Leo
tetrode I am a walking repository of thoroughly useless information 3,777 posts Likes: 6 Joined Jan 2006 Location: New York More info | Feb 09, 2011 12:08 | #9 PacAce wrote in post #11807598 Thanks for the clarification, Dave. So, the Eli adapter is really only useful for adapting PCB stobes and others that use the Balcar mount due to the thickness of the Eli adapter? Never thought of it that way but it does make sense since the Balcar mount is the only one I can think of that can be "flattened" to compensate for the thickness of the Kacey Eli adapter. Even on an AB light, Leo, the combined thickness of the Kacey adapters will move a Rotalux modifier away from the flashtube though not by very much. This was discussed at some length months ago on FM. Here are photos from that FM thread showing the effect of using the adapters with a 69" Rotalux: From the back: As you mentioned, Jerry's AB/Balcar adapter is flat as a pancake which definitely minimizes forward displacement of the Elinchrom mount. Bowens adapters are a different story. Even the almost flat Bowens speed ring insert I have is quite thick/tall. Adding an Elinchrom adapter to it would almost certainly guarantee that the back of an attached Rotalux modifier would sit ahead of the strobe's flashtube. Of course, much depends on the placement of the flashtube in the light itself and that is really what determines how well the combination will work. I should add that the 69" Rotalux mounted on an AB Einstein using Jerry's adapters (as pictured above) works very well indeed. Dave F.
| Latest registered member is griggt 1136 guests, 169 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
