Thread started 09 Feb 2011 (Wednesday) 14:14
A simple way of removing light pollution from images
naddieuk
Feb 09, 2011 14:14 |  #1
This is how I remove light pollution from my images. It is not perfect, but gives a good starting point. In DSS I always embed changes and never apply and save the tiff file with zip compression. Zip is lossless compression.
The first thing I do with Iris is set the working path. Press Ctrl R (File | Settings) and adjust the working path. I have a directory e:\camera where I store all my images in directories, so I have set that as the working path. This will then make Iris to save and load files from that directory (folder). This will now be saved when you exit Iris (I think).
The next thing I do is load the tiff file as saved by DSS and on the Threshold toolbar, I press Auto.
In the menu, I click on Processing and scroll down near the end to "Remove gradient (polynomial fit)". Both radio buttons are set to Medium and I also enable "Balance background colour", then click OK. When the image is filled with + signs, then on the Threshold toolbar, choose Auto.
To save the image, click on the icon which has two sets of >= to the right of the H icon. Click on the command window so the > is not highlighted.
Type in:
savebmp imagename
where imagename is the name you want to give the image. This is useful for further processing with Photoshop or Gimp.
savejpg imagename 1
will save as a high quality jpeg image with 1 indicating the highest quality.
The files will be saved into the working path we set at the beginning.
I hope this simple tutorial is helpful for someone.
Naddie
Canon Powershot S95, Canon EOS 1000D attached to Skywatcher Explorer 150P on an EQ-3 unguided mount.
My Flickr site. (external link)
martyn_bannister
Feb 10, 2011 11:54 |  #2
naddieuk wrote in post #11809808 (external link)
Type in:
savebmp imagename
savejpg imagename 1
Naddie
Not familiar with Iris, can you post a link? Would love to see some before and after images too.
naddieuk
Feb 11, 2011 05:33 |  #3
Iris is available here: http://www.astrosurf.c​om/buil/us/iris/iris.h​tm (external link)
Here are the before and after images. After some experimentation, I have found that instead of leaving the options on Medium, it is better to have them both on High.
I know that it is not perfect, but it has removed a large majority of the light pollution. There is some extra work required.
martyn_bannister
Feb 11, 2011 12:38 |  #4
I'd call that a stunning result!
ckckevin
Feb 13, 2011 16:38 |  #5
naddieuk wrote in post #11821173 (external link)
Amazing! Thanks, i may look into it!
Kevin life= learning
500D, Canon 10-22mm, Tamron 17-50mm 2.8, Canon 60 macro, Canon 85mm 1.8, Sigma 8mm 3.5, Sigma 30mm 1.4, Sigma 50-150mm 2.8, Kenko SP300 1.4x, efs extension tubes, 580EX, and lens that i don't like
naddieuk
Feb 14, 2011 03:06 |  #6
Thanks for the replies. It does need further work, but you can see how it can help. What makes it really good is that it is free and little effort is required. If you have found it helpful, it would be nice to see other before and after images.
6,602 views & 0 likes for this thread, 3 members have posted to it.
1360 guests, 188 members online
