Thread started 10 Feb 2011 (Thursday) 11:41
NEW 60D!! but my flash isnt supported?!?!
frontiermonkey
Feb 10, 2011 11:41 |  #1
Hey guys,
I just picked up my 60d last night WOOHOO! SOOOO much nicer than the rebel xs i have. I went to put my Quantaray QDC 900WA on and it will not fire. I blew my load on the camera and dont want to tell the wifey that I need MORE money. Any ideas? Anybody have this issue? Thanks in advance.
Ha I finally have a gear list!
Canon 60D, 18-135, 50 1.8, 55-250,
Canon Rebel XS 18-55. Some flashes and filters and a tripod with a bag to put it all in!
themadman
Feb 10, 2011 11:44 |  #2
I have no clue, but maybe this question would be answered faster in the Lighting section? Congratz on the 60D!
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
nepali
Feb 10, 2011 11:55 |  #3
frontiermonkey wrote in post #11815825 (external link)
Hey guys,
That cracked me up! :D
Anyway, have you checked the batteries? Does the flash have a test mode? If so, have you checked that? Also try cleaning the connectors on the flash.
[Current Gears: Fuji X-T4, Fuji 35 f/2, GoPro HERO8, YN-560 III]
[Feedbacks: #1, #2]
frontiermonkey
Feb 10, 2011 13:44 |  #4
BAHAHAHA I just realized how that looks when you put it in bold. D'oh! I will check batteries and contacts and then ask around in lighting.
L.J.G.
"Not brigth enough"
Feb 10, 2011 15:58 |  #5
EEERRRRK thanks heaps for putting that picture in my head :rolleyes:
Lloyd
Never make the same mistake twice, there are so many new ones, try a different one each day
Gear Flick (external link)r
frontiermonkey
Feb 10, 2011 17:01 |  #6
alrighty batteries are new. no test mode on the flash, and connectors cleaned. i took it off the 60 and put it on the xs and it worked fine. for some reason quantaray does not have a website(not sure why) so i cant get a hold of custom support which i think is b.s. I contacted canon and they get back to me as soon as possible. in the meantime if anyone can help please do, i hate the on camera overexposure light(flash)
MinnGreenGT
Feb 10, 2011 17:09 |  #7
ANY response from the flash? Does it have an AF beam or can you hear the head zoom when you zoom the lens, etc... (not familiar with that model flash specifically).
Have you tried shooting in full manual [M] mode to see if it fires then?
I've used my Yungnuo YN467 on my Dad's 60D and it works as-intended... <shrug>
Canon EOS 5Dmk2 | Canon 50mm 1.8 |
Canon 85mm 1.8 | Sigma 15-30mm | Sigma 24-70mm f/2.8 | Sigma 70-200mm f/2.8 | Bag-O-Cheap-Tricks |
frontiermonkey
Feb 10, 2011 17:14 |  #8
yeah i can hear the zoom in the flash. it works as a slave right now also. doesnt work in M either.
tim
Light Bringer
Feb 11, 2011 04:23 |  #9
Try a Canon speedlite on your 60D. A flash in M is really a very dumb device, with the single contact there to trigger it, if it doesn't work something's seriously wrong.
frontiermonkey
Feb 11, 2011 07:31 |  #10
Just got a response from canon. They say that since its not a canon they are sorry it doesnt work, and that i need to buy a canon ex speedlight. not much help there but oh well. plus unfortunately I dont know any other canon photographers that have a speedlight, so i cant try any flash unless im gonna buy it.
BaldPhotographer
Feb 11, 2011 08:18 |  #11
I had purchased an off brand flash and it won't work on my camera. Found out that when I tightened the flash to the shoe that the contacts were not making contact. Put a spacer between the flash and shoe so that it would tighten down farther and contact was made. Worked fine but felt that I shouldn't have to put a spacer every time I wanted to use the flash. Took it back and got a Canon flash.
nepali
Feb 11, 2011 09:49 |  #12
frontiermonkey wrote in post #11821436 (external link)
Browse the classifieds section. You can get a used 430EX for around $150. I would go this route or you can checkout Yongnuo flashes. They are very affordable.
[Feedbacks: #1, #2]
MinnGreenGT
Feb 11, 2011 09:51 |  #13
I was wondering if it might not be a contact issue as well. Do you have any off-camera triggers or something else you could put on the hot shoe to confirm that it's making contact?
Time to find a local friend with another flash... to at least help determine if it's a flash or camera issue.
Sgt.
Gallery: 56 photos
Feb 11, 2011 10:39 as a reply to  @ MinnGreenGT's post |  #14
Is there a custom function on camera for firing flash??
Iain
7D MKII
Another minion in the Pondrader fan club
Bumgardnern
Feb 11, 2011 10:49 |  #15
Check to see if your hot shoe is working. Also make sure the flash is making a connection to the hot shoe. You can also try connecting the flash to camera via pc connection.
4,385 views & 0 likes for this thread, 16 members have posted to it.
2915 guests, 142 members online
