Thread started 10 Feb 2011 (Thursday) 12:06
General Purpose Seamless Paper ... What Color?
jdang307
Feb 10, 2011 12:06 |  #1
I want to hang a roll of seamless paper up. Ideally I'd get a few rolls with several colors, but for now, just one. My main purpose is to shoot video (short videos for my law firm). Any idea what color background is most pleasing yet professional for business? Light gray? Dark Gray? An ivory color?
Since I have it, I might as well shoot some portraits as well. Any suggestions on first colors would be greatly appreciated.
k.CHU
Feb 10, 2011 12:07 |  #2
Do you have any lights? id go with light gray.
Kevin Chu Photography (external link)
Canon 5DII | 85 1.8 | 50 1.8 | B800(x3)
Flickr (external link) (Jan 2011) | Facebook (external link)
jdang307
Feb 10, 2011 12:15 |  #3
No lights, yet. It'll be in my garage so I'm going to test with natural light (heh) but if you have any suggestions for cheapo lights I'm all ears. Maybe some cheap clamp lights with the CFL's. I do have a speedlite 580exII but obviously I can't use that for video.
hawk911
Feb 10, 2011 12:57 |  #4
thunder gray or white! white will look gray anyway if you're not lighting it properly to get pure white.
HAWK Photography Gallery (external link) FB Fan page (external link)|_My gear: 5d3, 70D & 40D (all gripped), 580exII, 550ex, Canon 24-70 L & 85 f1.8, 50mm f1.4; Tamron 70-200 SP Di VC, Canon 18-55, Sigma 1.4xtc; Elinchrom Whore, Skyport triggers, Speedotron BD and Kacey Grid, Vagabond minis
Muggsly
Joined Nov 2010
Feb 10, 2011 13:37 |  #5
hawk911 wrote in post #11816302 (external link)
I second the thunder Gray paper. It works wonders you can light it or not and get different shades all the way to black. It also reacts well to gelling strobes only holding color in smaller areas. I also like Coco Brown it is nice and earthy and very usable with a lot of skin tones.
Light makes photography. Embrace light. Admire it. Love it. But above all, know light. Know it for all you are worth, and you will know the key to photography. - George Eastman
Gear List if you are a curious voyeur type take a look
Lyle ­ Krannichfeld
Feb 10, 2011 17:43 |  #6
White, for sure...you can go from white to grey to black with it as well as use gels to color the background. Zack Arias has some great articles on his blog about it (zarias.com)
Fine Art Landscape/Wildlife Photographer on Maui: INSTAGRAM (external link) FACEBOOK (external link)
Tonga tours to swim with the Humpbacks: AUMAKUA TOURS (external link)
Sony A7R IV, A7RIII, 12-24G, 16-35GM, 50 1.4ZA, 85 1.4GM, Voigt 65, Laowa 100 2:1 macro
DJI Inspire 2 with X7 and 16, 24, 35, 50
k.CHU
Feb 10, 2011 18:21 |  #7
I would not go thunder gray or black... since OP has no lights to use, hair might blend into the dark background... white or light gray for me.
Lyle ­ Krannichfeld
Feb 10, 2011 18:33 |  #8
Oooh ,sorry..didn't see the no lights part...I'd recommend some digging around on strobist.com, good info on cheap lighting to get started.
hawk911
Feb 10, 2011 19:12 |  #9
no lights then gels don't matter, but gelling white isn't the greatest result.
jra
Feb 11, 2011 05:55 |  #10
hawk911 wrote in post #11818740 (external link)
Just to add, gelling white BG's won't produce colors nearly as nice as gelling a gray background. Considering the op doesn't have any lights, I guess this is a moot point at the moment :)
You can see the results of gelling a gray background here>>> www.secondglimpse.com/​background (external link)
TMR ­ Design
Joined Feb 2006
Feb 11, 2011 06:30 as a reply to  @ jra's post |  #11
It's all about control. You can turn black seamless white, white seamless black, gray can go either way and you can gel any of them.
Most often it seems that people using gels want those rich, saturated colors. Black makes that the easiest but a roll of black seamless isn't always the most versatile. For the greatest versatility and ability to gel easily I would go with a studio gray, thunder gray, smoke gray, etc.. Those are all a bit darker than middle gray.
Robert
Mark1
Feb 11, 2011 07:45 |  #12
1 white
1 grey
1 black
That is all you will ever need. As Robert mentioned it is all in the lighting. With a few gells you can have any color you want. White to black. White lit with gells are a soft kinda pastel colors, grey a bit more solid, and black bold colors. More or less light will vary the colors to just about anything you want.
hawk911
Feb 11, 2011 08:27 |  #13
for me, any gel on white was just washed out, but that was also 2 yrs ago in my learning curve. I should try again
TMR ­ Design
Joined Feb 2006
Feb 11, 2011 08:47 |  #14
hawk911 wrote in post #11821694 (external link)
It's only washed out because you're not achieving the correct balance between subject and background exposure.
If you use black as an example, then the background needs to be 4 stops reflective under the incident subject exposure. Easy to do with black seamless.
Put a piece of white seamless in its place and everything changes. This is where the control comes in.
You need to produce enough light in your subject exposure so that you're still 4 stops over the reflective reading of the background and you MUST have proper isolation of the subject from the background so that none of the subject lighting reaches the background. In many cases we don't notice that spill with gray or black because we can still get nicely saturated colors. With the white background, every bit of light reaching it brings up the exposure and minimizes the difference between subject and background, making the background lighter.
Robert
jra
Feb 11, 2011 09:17 |  #15
Producing vibrant colors on white is difficullt for the reasons you've just mentioned. It's very difficult to produce a black background with white seamless given the space restraits that we're often required to work in (such as reflective walls and not enough room to seperate subject from BG). Because of that, gray is a far better choice for flexibility iMO.
5,079 views & 0 likes for this thread, 9 members have posted to it.
1758 guests, 174 members online
