Lately I've been noticing that I'm catching the shutter curtain at about 1/160th of a second when using flash. Happens over and over again. Quite annoying when trying to get the ambient just right.
mikekelley "Meow! Bark! Honk! Hiss! Grrr! Tweet!" 7,317 posts Likes: 16 Joined Feb 2009 Location: Los Angeles, CA More info | Feb 12, 2011 21:36 | #1 Lately I've been noticing that I'm catching the shutter curtain at about 1/160th of a second when using flash. Happens over and over again. Quite annoying when trying to get the ambient just right. Los Angeles-Based Architectural, Interior, And Luxury Real Estate Photography
Gedanken Senior Member 741 posts Joined Mar 2007 Location: Melbourne, Australia More info | Feb 12, 2011 21:54 | #2 I haven't had a problem at 1/160 or 1/200. What settings are you using?
smorter Goldmember 4,506 posts Likes: 19 Joined Nov 2007 Location: Melbourne, Australia More info | Feb 12, 2011 21:58 | #3 It depends on the trigger, I believe wireless ETTL and pocket wizards sync at 1/200 but things like yongnuos and optical slaves sync at slower than 1/160 Wedding Photography Melbourne
Muggsly Member 153 posts Joined Nov 2010 More info | Feb 12, 2011 22:13 | #4 I use Pocket wizards and Cybersyncs and I sync at 1/200. What triggers are you using? Light makes photography. Embrace light. Admire it. Love it. But above all, know light. Know it for all you are worth, and you will know the key to photography. - George Eastman
Gedanken Senior Member 741 posts Joined Mar 2007 Location: Melbourne, Australia More info | Feb 12, 2011 22:15 | #5 smorter wrote in post #11831788 It depends on the trigger, I believe wireless ETTL and pocket wizards sync at 1/200 but things like yongnuos and optical slaves sync at slower than 1/160 Not necessarily - just a quick test shot on the 5D at 1/200 with RF-602s:
toxic Goldmember 3,498 posts Likes: 2 Joined Nov 2008 Location: California More info | Feb 12, 2011 22:19 | #6 Shutter curtains showing up can be inconsistent at times. Low batteries in the triggers can slow down the triggering too.
mikekelley THREAD STARTER "Meow! Bark! Honk! Hiss! Grrr! Tweet!" 7,317 posts Likes: 16 Joined Feb 2009 Location: Los Angeles, CA More info | Feb 12, 2011 22:22 | #7 I'm using PocketWizard Mini/TT5/Ac3. It even shows up at 1/125th sometimes. Odd. Los Angeles-Based Architectural, Interior, And Luxury Real Estate Photography
Hoppy1 Senior Member 841 posts Joined Sep 2005 Location: Midlands, UK More info | Feb 12, 2011 22:40 | #8 mikekelley wrote in post #11831907 I'm using PocketWizard Mini/TT5/Ac3. It even shows up at 1/125th sometimes. Odd. Have you set these up for your camera? You can get at least 1/250sec out of a 5D2 in custom HyperSync mode. 5D should be the same. 5D2, 17-40L, 50/1.8, 24-105L, 70-200L 4 IS, 580/270EX, Strato II/RF-602, Elinchroms
mikekelley THREAD STARTER "Meow! Bark! Honk! Hiss! Grrr! Tweet!" 7,317 posts Likes: 16 Joined Feb 2009 Location: Los Angeles, CA More info | Feb 12, 2011 22:46 | #9 Yeah I've set them up, tinkered with and adjusted to the newest firmware etc. I can get high sync speeds up to 250th - just not consistently. Just kinda aggravating when it's not an every-time thing, you know? Los Angeles-Based Architectural, Interior, And Luxury Real Estate Photography
smorter Goldmember 4,506 posts Likes: 19 Joined Nov 2007 Location: Melbourne, Australia More info | Feb 12, 2011 22:49 | #10 It depends on your ambient vs flash exposure too. if you are using flash as fill, you won't notice it at the edges, but if you totally cut ambient and your flash is hitting the entire frame, then you will notice it (e.g. in a studio environment) Wedding Photography Melbourne
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | Feb 12, 2011 22:56 | #11 Probably an overly simple suggestion, but are your batteries for the wireless triggers/receivers well charged? I have seen that cause a slight delay which results in shrinking sync speed. Taylor
themadman Cream of the Crop 18,871 posts Likes: 14 Joined Nov 2009 Location: Northern California More info | Feb 12, 2011 23:04 | #12 I have noticed this with my 5D as well. My rf-602 work flawlessly with my 7D, but my 5D needs a slow down in shutter speed. Will | WilliamLiuPhotography.com
bobbyz Cream of the Crop 20,506 posts Likes: 3479 Joined Nov 2007 Location: Bay Area, CA More info | Feb 13, 2011 00:04 | #13 mikekelley wrote in post #11832037 Yeah I've set them up, tinkered with and adjusted to the newest firmware etc. I can get high sync speeds up to 250th - just not consistently. Just kinda aggravating when it's not an every-time thing, you know? What settings? For some reason black bar at 1/250. I think I need to increase than offset from -570 to more -ve value. BTW - I have heard some 5d only managing 1/160 irrespetive of which trigger method you use. Fuji XT-1, 18-55mm
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Feb 13, 2011 00:52 | #14 Remember that when the shutter opens and flash outputs its light, there is a latency in which the flash is NOT putting out light...and this period is longer for some studio flashes, so even 1/200 might be too fast and it is necessary to resort to an even slower 1/160 or even 1/125. Now stick a radio trigger in between, and we now add latency of the trigger send a signal and the receiver getting the signal and responding by triggering the flash unit, so even a flash unit which used to be able to work successfully at 1/200 might now be slowed down by the radio trigger to 1/160 or 1/125, and hypothetically the slow flash might be further reduced to even slower 1/80 or 1/60! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
ootsk Goldmember 1,154 posts Likes: 13 Joined Jan 2002 More info | Feb 13, 2011 02:32 | #15 It's totally pathetic. Sell them, and stick with whatever you used to use to get the "ambient just right."
| Latest registered member is semonsters 1676 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
