Is the lastes 18_55 IS kitlens considered generally better than the older 17-85 efs IS lens?
The 17-85 seems to have a bad rep around here and there.
datadump Goldmember 1,932 posts Joined Oct 2007 Location: Canada More info | Feb 13, 2011 11:00 | #1 Is the lastes 18_55 IS kitlens considered generally better than the older 17-85 efs IS lens? datadump
Feb 13, 2011 11:06 | #2 Do a bit of search CANON 6D - SONY A6000
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | Feb 13, 2011 11:20 | #3 datadump wrote in post #11834395 Is the lastes 18_55 IS kitlens considered generally better than the older 17-85 efs IS lens? The 17-85 seems to have a bad rep around here and there. yes, the 18-55IS kit lens is definitely sharper than the 17-85IS on a crop model
In actual use, a Canon 18-55mm image stabilizer lens generated these pictures.
The 18-55 IS lens had no problems generating these images. There's nothing to worry about when using the lens.
LeeRatters Cream of the Crop More info | Feb 13, 2011 12:40 | #5 i actually found the 17-85mm the better of the two - all IMO of course
Feb 13, 2011 12:57 | #6 watt100 wrote in post #11834498 yes, the 18-55IS kit lens is definitely sharper than the 17-85IS on a crop model see: http://www.the-digital-picture.com …omp=0&FLIComp=3&APIComp=2 or www.photozone.de oh of course.. the digital picture comparo site .. thx. datadump
DazJW Senior Member 319 posts Joined Jan 2010 Location: Teesside More info | Feb 13, 2011 13:00 | #7 I replaced my 18-55mm IS with a 17-85mm IS USM and other than the fact it felt a lot better to hold (I have big hands) and it having USM (I like proper focusing rings, full time manual and the fast USM autofocus itself) I didn't like it.
Feb 13, 2011 15:37 | #8 watt100 wrote in post #11834498 yes, the 18-55IS kit lens is definitely sharper than the 17-85IS on a crop model see: http://www.the-digital-picture.com …omp=0&FLIComp=3&APIComp=2 or www.photozone.de Interesting when you change the focal range to 50 look at the result: CANON 6D - SONY A6000
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | Feb 13, 2011 16:06 | #9 borism wrote in post #11835853 Interesting when you change the focal range to 50 look at the result: http://www.the-digital-picture.com …omp=0&FLIComp=4&APIComp=1 . you're looking different focal lengths and different apertures in that link
Feb 13, 2011 16:16 | #10 watt100 wrote in post #11836030 you're looking different focal lengths and different apertures in that link fail ! same focal length, same aperture, same camera http://www.the-digital-picture.com …omp=0&FLIComp=3&APIComp=1 True CANON 6D - SONY A6000
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | Feb 13, 2011 16:54 | #11 borism wrote in post #11836105 True There: http://www.the-digital-picture.com …omp=0&FLIComp=4&APIComp=1 f5.6 on both, cant see at 55 on the 18-55 The point remains IMO different focal lengths
Feb 13, 2011 16:58 | #12 watt100 wrote in post #11836319 different focal lengths fail again ! nice pics (and MTF image resolution data) at www.photozone.de same focal length, same aperture, same camera http://www.the-digital-picture.com …omp=0&FLIComp=3&APIComp=1 Again my point haven't change if you read my post CANON 6D - SONY A6000
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | Feb 13, 2011 17:03 | #13 borism wrote in post #11836335 Again my point haven't change if you read my post Plus no real life difference between 50 to 55 IMO, but I applaud your competitive post hint: for other comparable image resolution data on lens (with the same focal length) look here
Cesium Goldmember 1,967 posts Likes: 1 Joined Jun 2009 More info | Feb 13, 2011 19:07 | #14 In my experience with the two: 18-55 is better at the wide end, and 17-85 is better at the long end.
Feb 13, 2011 21:14 | #15 thanks all for the info. i think the latest kitlens with IS seems fairly impressive. and its pretty lightweight. it might fit the requirements for the lady. i still think i'll get her a 35 f/2 on the side... datadump
| Latest registered member is semonsters 1463 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
